RE: Making a Good Landing
Go 1 or 2 sizes larger on the tires, that will help you out. Also, I cut my grass at 2" and overseed it yearly so the weeds have a harder time, and the nap of the grass is more consistent. I also use a 2000 lb roller a couple of times a year to help make it smoother. ( A slightly wet spring is best time, just not when the ground turns to bog...)
