ORIGINAL: Tony Hallo
Yea I hear what you're saying but two perfect flights and then everthing goes south without warning? Runs good on the ground but not it the air? Things are not adding up.
ivae had issue like that doin my high end.... on the ground it never skips a beat, in the air wot doing a fast flybye tthe engine will skip a beat... i land, then go in a little on the high till it goes away.... the best thing i have found is lean in the groung with engine running and find the peak till it loses rpm then back out to peak and a hair more and yur good to go....
