RE: What mixture do you use to clean your plane ?
When I clean a model after a season or when I work on it (like no, converting a Giant stick to electric) what I use at home is Mr. Clean diluted 50% in hot water. It leaves the monocote shining like new. Never had a problem. In the past, at the field I used Windex straight from the spray bottle. Now, since I gave up slimers, with gas an electrics, cleaning is not a real issue. Electrics just get dusted. Passers get cleaned at home (also w/Windex).
Gerry
