RE: Help Identifying pattern model
The main gear is classic Rhom air’s with Kraft wheels. The hot setup from this period. The nose gear as you describe it is not Rhom. The Rhom tanks had two air lines. Are you sure the air line going to the vertical isn’t just the second tank line that flipped to the back of the fues? Is the control valve a square aluminum manifold looking thing? Like to get some pics of the innards..
