RCU Forums - View Single Post - Help Identifying pattern model
Old 09-02-2011 | 06:36 PM
  #35
iiiat's Avatar
iiiat
Default RE: Help Identifying pattern model
Pitstop... whatchoo talkin' 'bout Willis? LOL
Edh... yep.. the mains are definitely Rhom Air. I'm familiar with those. I'm attaching more pics. I haven't had the air tank out and I can't reach back far enough to tell if there's another nipple on the back side. I have a good shot of the nose gear, so you can confirm your guess from my description. And, as you can see... the one airline goes all the way back into the vertical fin. And it's pretty well stuck in there. I haven't tugged on it very hard not knowing if it's supposed to be up there for some reason. From what you tell me, I'll bet it was meant to go on the back of the air tank. As you can see, there isn't an air control valve or filler or anything else. As I said before, this plane was never setup to fly.
Tom
ID:	1656620   Click image for larger version
ID:	1656621   Click image for larger version
ID:	1656622   Click image for larger version
ID:	1656623   Click image for larger version
