RE: Sam-Rai Build Thread
After removing the wing you have to clean up the wing seating.
Sand the sides of the fuselage flush. Wing fillets are not allowed in Q500.
A Dremel tool was used to remove micro-balloons around the aileron horns.
I re-tapped the bolt threads and added access holes behind the rear bolt holes.
