RCU Forums - View Single Post - SD-10G Programming
Old 09-05-2011 | 11:23 AM
Nathan King's Avatar
Nathan King
Default RE: SD-10G Programming
I did the same thing for my snap rolls by "AND"ing the traditional switch with a stick switch. When the switch is engaged AND my ailerons are over 80% of travel my throws change. Set your setup to "OR" and you'll have high rates when the throttle is idle. The plus is that if you want high rates at a high throttle setting you can override it with the switch, but only if it is programmed as "OR."
