RCU Forums - View Single Post - full composite Wind S pro -Sebart
Old 09-05-2011 | 11:51 AM
s-chester
Default full composite Wind S pro -Sebart
Hello
Recently came out completely composite Wind S pro version without a lot of information on model, not in building or Flying
Of course I like the balsa wing model , it does a great job.
So I wanted another one In case, for Flying wrong / bad luck / Radio Interference in 2.4 / All / Other ... and it breaks
composite version is different not only in the materials, weight and strength but also in geometry, I think stability and some aerodynamics ?
This topic will introduce the mine construction process and the possibility comparing the two aircraft balsa wing with composite
The majority information will be pictures because I write very slowly in English
Therefore, I apologize
Shlomi Chester
Israel F3A Team
ID:	1658593   Click image for larger version
ID:	1658594   Click image for larger version
ID:	1658595   Click image for larger version
ID:	1658596   Click image for larger version
ID:	1658597   Click image for larger version
ID:	1658598   Click image for larger version
ID:	1658599   Click image for larger version
ID:	1658601   Click image for larger version
ID:	1658602   Click image for larger version
ID:	1658603   Click image for larger version
