RE: Another Fliteskin ME 109 build thread
Jose - Thank you for the YouTube. Looking at this give me goose bumps. I have the DVD"One Summer - Two Messerschmitts" and it is the best aviation DVDI own (and I own quite a few...). Ican listen to the DB605 and watch the Me-109 take off and land all day...
The Tempest will be very interesting. The easiest scale engine installation ever...
As to the weight, I will have heavier engine then you (the MVVS 30cc Petrol), and have the weight of the ignition + ignition battery, not to mention that I may have more servos in the wing. Iwill be very surprised if Iwill end up under 7Kg... Once I finish the one side of Fliteskin covering Iwill get the heavy model inspector to look at the wing before Iclose it so he will have confidence in the construction (which will make certification easier).
Ialso had time to make some progress today. The left wing is starting to take shape on the building board. This time, Ihave glued the plywood doublers to W2 and W3 before pinning them to the building board, it was easier that way.
