RE: SD-10G limit travel question
Our "max limit" does not work the same as Futaba. The Max Limit is an overdrive limiter to prevent over driving the servos, especially in situations where the servo "could" travel farther than the control surface would allow (for example a glider where the live hinges only travel so far before stuff starts breaking). If you have the epa's higher than the "limits" you will have dead space at the end of the stick travel. It is not re-calculating the way Futaba does.
So, leave the limits alone (all the way up) and Max on the epa and max on the d/r (for the highest setting) will give you max travel and max resolution.
