RCU Forums - View Single Post - Skymaster F4 pipe and wet start
Old 09-06-2011 | 04:43 PM
Countryboy's Avatar
Countryboy
My Feedback: (25)
Default RE: Skymaster F4 pipe and wet start
Nuno,
That is too much of an angle on the turbine. You should have 3-5 degrees max. There should be mounting blocks glued to the former and below the turbine mounting rails to which the pipe straps bolt to. In other words, the pipe mounting straps will be below the turbine mounting rails. Hard to tell from the pics how you have the front of the pipe secured.
