RCU Forums - View Single Post - CALDERA 10E - UPGRADE RECOMMENDATIONS???
Old 09-06-2011 | 05:33 PM
FatherDeath
Default RE: CALDERA 10E - UPGRADE RECOMMENDATIONS???
<table width="100%" cellspacing="1" cellpadding="4" border="0"> <tbody> <tr> <td width="150" valign="top" nowrap="nowrap" bgcolor="FBFCFF" background="/forum/image/ffffff" class="ultrasmall">[img]../../../image/blank.gif[/img]</td> <td width="100%" valign="top" bgcolor="FBFCFF" background="/forum/image/ffffff" class="msg">Having some problems... and I'm not too happy with this Caldera right now. <div style="background-color: rgb(255, 255, 255); padding-top: 5px; padding-right: 5px; padding-bottom: 5px; padding-left: 5px; margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; font-family: Arial, Verdana, sans-serif; font-size: 12px; ">
1. Transaxle rattle.. same as posted in this forum.
<span style="color: rgb(153, 204, 0);"> I found that all the differentals on my redcat need grease or lube put in them, and most need shimmed just a touch to get rid of the rattle</span>
2. Remote control only goes to about 30 yrds, and then complete control loss... which means it may slam into a tree or fly off a cliff.
<span style="color: rgb(153, 204, 0);"> I upgraded mine to the Flysky GT3B </span>
3. After 1 battery worth of use, 2 of my lower shock screws are gone...
<span style="color: rgb(153, 204, 0);"> Use Blue threadlock on ALL the screws... They tend to vibrate lose if your not careful. Make sure you do this to the wheel nuts as well</span>
4. Reverse needs tweaking
<span style="color: rgb(153, 204, 0);">Reverse has a mind of its own.. Sometimes it works great sometimes not at all.. I have 4 redcats and they all are the same..</span>
I am frustrated with this truck.
My friend brought his Traxxas over, and the Caldera SMOKES it, and out climbs it... but he retains control of this for at least 50 solid yards. (Long antenna on his remote)
I can't even stretch this things legs all the way it is so limited with range.
Granted, this is one of my first rc vehicles other than a chopper, but I certainly expect more out of the box for 190.00. Especially if you have to spend 75.00 on upgrades just to make it work decently.... Why not just buy a better one ?
I would truly appreciate it if someone could tell me what to do to make this thing work well. I like it, I just think it has some weaknesses that make it annoying.
I've had it 2 weeks and only gotten 2 batteries worth of use because of things breaking.
Only thing I have done so far is get two 7.4V batts... makes it run great, and has good life, if the truck would stay together.
-and I'm only running it on flat ground in a park... nothing crazy.
1. Can I upgrade the transmitter? Is it worth it, or should I just get another truck instead ?
<span style="color: rgb(153, 204, 0);"> Yes you can I have the Flysky GT3B there about 35 bucks at hobbypartz and it works great and you can tweek alot of things right from the transmitter.</span>
2. Do I need to replace the transaxle, or can I just run it until it stop functioning?
<span style="color: rgb(153, 204, 0);"> It is prolly just the front ring an pinion in the transaxle.. the rebuild kits are fairly cheap and easy to rebuild... Sence you are gonna have to replace or rebuild it eventually might as well run it as long as you can
</span>
Thanks !!! </div> </td> </tr> </tbody></table>
