RE: Skymaster F4 pipe and wet start
Hi
Thanks for your replies.
I took some pics of the old pipe and found out what the problem is. The new pipe is not properly built. The exhaust angle is bigger in the new pipe, so to have the exhaust exit straight, The angle in the turbine as to be bigger. Pic. 3 is new pipe and pic. 4 is older pipe. As you can see the angle is quite different.
Unfortunately, it is the second time Skymaster send me an incorrect pipe and I am waiting for more than 4 monthes to maiden this plane[:@][:@]
I have already reported this problem and asked for a correct pipe for the second time and no reply till now. I will be at JetPower and return this to them. Hope to have a correct one, FINALLY...
Regards
Nuno
