RE: Dihedral for Kadet Sr. Nitroplanes
If you're working with an instructor the dihedral really isn't necessary. The plane is still going to be stable in level flight and will be better in the wind without it. The real value of dihedral is that you can let go of the sticks if you get disoriented and the plane will return to neutral all by itself, assuming you have enough altitude at the time.
