RCU Forums - View Single Post - .60 size Pattern Tiporare Build
Old 09-07-2011 | 01:43 PM
  #178
Jim Clausen's Avatar
Jim Clausen
Default RE: .60 size Pattern Tiporare Build
I finally had a humidity low enough to prime the fuselage. I thought that I had done a good job sanding and contouring but that is not the case. I have low spots, high spots and poor contour in several places. I think that my next move is to sand everything out with a block and fill all of the low spots and get the contours better. It does not have to be perfect but I do not want to be embarrased with my modeling efforts. Apparently this is going to take some time. Since this is my first try at making contours from wood I guess it isn't all that bad but I would like to be better.
Jim
