RCU Forums - View Single Post - Differential Gear Set Problem?
Old 09-08-2011 | 01:04 PM
NewRageRC
Default RE: Differential Gear Set Problem?
What kind of car is this? What you're showing seems to be part of a 2 speed transmission, not a differential. My best guess is you need some shims. Or maybe you need to put the smaller gear on the shaft from the opposite end of the shaft.
