RE: Convert Millimeters to Degrees
I agree with CGRetired! Talk about making rocket science that is not necessary. Just measure the throw at the outboard tip (or inboard tip if specified) of the trailing edge of each control surface directly with a ruler in mm.
Of course you can use trigonometry to get to degrees using the surface chord length but why complicate things?
