RE: Startup Questions, Gas CAT
Nice looking hull. killerbeeRC has a off switch that plugs into the black plug. ground to base on the other line. If you loose signal or you turn off your transmitter, shuts down the engine. Setup your receiver to back throttle the carb shut. end point adjust your throttle. When you come off pipe and start to slow down. She will stall out. practice come in at a angle until you get the feel. .
