RE: KMP / YT FW-190 Build Thread
mines set at 138mm the flys well with a satio 170r in her (at 150mm back you will be picking up parts on your first flight) ballance it up side down with the retracts retracted note when you drop them to a landing state the nose will drop with the forward shift off the wheels. if you at all worried try setting the COG at 138 the factory setting is 140 i know that sounds daft but its a very sensitive plane it regards the COG a tiny bit of weight makes a huge diffrence
