RCU Forums - View Single Post - Help Identifying pattern model
Old 09-08-2011 | 08:34 PM
  #49
EscapeFlyer's Avatar
EscapeFlyer
Default RE: Help Identifying pattern model
ORIGINAL: crankpin
Lot of ID pro's here. Not trying to steal anyone's thunder, can you guys give me your opinion on this ? Guy told me it was a Curare, because it had a bent stab. Best I have found from other's, it is an Atlas. A Tipo wing chord not the same.
Crank
Does it have a straight wing?
It the wing has any taper or sweep I would be WAAAY OFF!
Could it be a modified later El Camino with anhedral? I believe there were 2 variants of the El Camino. I could be way off though...
Brian
