RCU Forums - View Single Post - Tech-Aero Regulators
Old 09-09-2011 | 09:04 AM
OhD
Default RE: Tech-Aero Regulators
ORIGINAL: klhoard
ORIGINAL: RC11
I too use the Tech-Aero set up with two 360 Rhinos. It occured to me that I might just draw from the two flight batts via the balance taps tapping into 2 cells thus eliminating the Rhinos, their weight and charging. Why not?
Pros and cons please....
RC
Just don't try to run two regulators off the same motor pack, they will have a common ground and the magic smoke will escape. You want a completely separate backup system, both electrically and physically. . .
What is wrong with a common ground? Seems like you have a common ground as soon as you connect each regulator to the receiver.
Jim
