RCU Forums - View Single Post - CD Ignition wire replacement.
Old 09-09-2011 | 09:42 PM
Tired Old Man
Default RE: CD Ignition wire replacement.
And if not, you have great access and it's an easy modification to get to an auto advance arrangement. Just drill a vertical hole in the white ring that will tap to 6-32 or 8-32 for a set screw, determine 28* btdc, and lock it down. Remove the coupling linkage, plug in the ignition, and go fly.
