RCU Forums - View Single Post - CD Ignition wire replacement.
Old 09-09-2011 | 09:47 PM
  #31
Props4ever
Default RE: CD Ignition wire replacement.
ORIGINAL: Tired Old Man
And if not, you have great access and it's an easy modification to get to an auto advance arrangement. Just drill a vertical hole in the white ring that will tap to 6-32 or 8-32 for a set screw, determine 28* btdc, and lock it down. Remove the coupling linkage, plug in the ignition, and go fly.
Can u pls illiterate how to do this by using my pictures, also if you can make arrows on each part with there names, it will be easy for me to know what part is what ie: coupling linkage, plus how to lock it down etc etc...
Thanks in advance.
