RE: Nitro Engine Troubleshooting and Tuning
Temperature definitely affects the tune of a nitro engine. If the coil is pulled in it was running too hot/lean.. usually you richen the mix for a hot plug. Start with base settings (3 out on each needle from closed snug) and tune from there.
