ORIGINAL: alexchen86
Wow super fast replies...I should have explained my running gear first. First thing is yes LVC is set at 3.2V/cell via Castlelink as I know I'm using subpar lipo packs.
I'm using the Turnigy Nanotech 2s 25C lipos on my Losi XXX-SCB outfitted with Castle's SCT 1410 3700kv combo.
Outside temperature was around 95 degrees. ESC temp after a full pack was 126 degrees and the motor was at 114 degrees so nothing was overstressed.
Lipo batteries hitting 100 degrees isn't too bad of an issue it was still warm to the touch and it wasn't even puffed. The weird thing is one of them puffed several hours later. I guess I need packs with at least 30C?
I don't understand...the Losi XXX-SCB is super light and weighs no more than maybe 3 pounds RTR weight including battery.
Set the lipo cutoff at auto-cutoff..
