RCU Forums - View Single Post - need to help with balance.
Thread
09-11-2011 | 03:40 AM
6
bingo field
May 2004
1,732
Mt. Morris, NY
RE: need to help with balance.
also make sure you're not on a compression (exhaust or ignition) stroke, the prop should be loose on the crank, just when you're using it to test lateral cg of course...
You can tighten it up after..
Reply
Like
bingo field
View Public Profile
Send a private message to bingo field
Find More Posts by bingo field
View iTrader Profile
