ORIGINAL: armyguy466
my Nexstar wing is set up as a dual servo because i couldn't use the single servo the built in arms to the ailerons was really out of wack. this plane has been a problem from day one on its first take off it made it about 3 feet up and the fire wall ripped and the plane smashed nose first into the ground. its not over powered it only has a .46 size motor one thing about the nexstar is they look nice but if you get the select its better QC and the ARF like i have are from bottom of the barrel.
Ah.. well, in that case...
CGr
