RCU Forums - View Single Post - full composite Wind S pro -Sebart
Old 09-11-2011 | 10:48 AM
s-chester
Default RE: full composite Wind S pro -Sebart
The Rudder original hinges wer not enough durable ,needed to replacing the hinges after about 450 flight, the experience from the first model, so I chose to use a little more durable hinges but more heavy
Aileron horns arms are replaced by carbon fiber because of 3 mm holes where drilled, it does not fit 2mm bearing Link screw
ID:	1660671   Click image for larger version
ID:	1660672   Click image for larger version
ID:	1660673   Click image for larger version
ID:	1660674   Click image for larger version
ID:	1660675   Click image for larger version
ID:	1660676   Click image for larger version
ID:	1660677   Click image for larger version
