RCU Forums - View Single Post - full composite Wind S pro -Sebart
Old 09-12-2011 | 02:32 AM
s-chester
Default RE: full composite Wind S pro -Sebart
The outer wing tube (socket) in the fuselage is very weak and badly glued together with the fuselage
Try to stick it to the fuselage and strengthen it in thickening the layers of the tube
maybe fiber glass layers
Maybe the inner surface of the nose ring is not parallel to the outer surface of the nose ring
Which will require you to make a spacer part for the right nose angle of the motor
not in all of the kits
the outer surface of the nose ring is o.k for reference the down & side thrust
Chester
