RE: Startup Questions, Gas CAT
CK out " ME TIME LIVE" You can watch a race anytime you want. That hull you have will do well in semi rough water. Add more flotation if your unsure. You can get a good Futaba 2.4 gig FASST radio system. you can add on any new hulls if needed. 6 volts 1200 amp hump pack will work inside the radio box. All from your local hobby shop. Joes servo mounts can be epoxy down into a pool of 30 min epoxy the longer the set time the stronger the epoxy
