ORIGINAL: QSR1
I have that manual, I just dont get it
need in laymans terms
I will keep trying thanks
Yeah, i have the same truck..I also found it a little confusing. But finally got it right!
1 - have both ESC and Transmitter turned off.
2 - Turn on Transmitter
3 - Hold Set key down (little button on the ESC)
4 - Turn on ESC while holdling down the set key...keep holding it down, you will first flash through about 9 red lights, then one green light..then a two green lights, then three greenlights...right after you count the three flashing greenlights, release the set key.
5 - Now press the set button again. this will put you in the low voltage cut off section. Choose your cuttoff voltage. I set mine to 2.6v.
Once you have it set just turn off the ESC.
