RCU Forums - View Single Post - Black Magic with Inrunner?
Old 09-13-2011 | 07:08 PM
ExFokkerFlyer
Default RE: Black Magic with Inrunner?
Emory,
I made the templates in TurboCAD, printed them out, and cut the pieces out of some carbon laminate that I had. Honestly, it really wasn't all that difficult to come up with, just work backwards from the firewall... where does the spinner need to be, what is the distance to the firewall? And work back from there. I had a bunch of pieces parts from various mounts over the years and just kept playing with different combos until it worked. It wasn't light, but then again, it wasn't all that heavy either... weighed about the same as the outrunner combo give or take an ounce. The outrunner is heavier, but there are more pieces to the inrunner mount.
For the Hacker, I just used the same rear piece and came up with a different front piece since the mounting is completely different. I used a non-comp C50 14xl and have that pattern too if you need it.
System worked out pretty well, wish I could say the same about the motor. I hear they are better constructed now, but since I had mine in three times in less than a year, with only about 100 flights on it, I was not impressed. I got it fixed up with the latest mods and sold it. Now, with my luck, it's probably been trouble free since... But I will never own another Neu under any circumstances because of my experience. Expensive paperweight to me.
But anyway, the power combination of the Neu and the Black Magic was pretty good and if you decide to go that way, you will not be wanting for any power.
I posted the jpg versions of the templates, if you want or need a better version, PM me with your address and I'll email either a PDF or something more usable for you.
Tom M
ID:	1662070   Click image for larger version
