RCU Forums - View Single Post - Checking CG?
Thread: Checking CG?
Old 09-14-2011 | 02:50 AM
jetmech05
Default RE: Checking CG?
On a mid wing it would depend on where the weight is...if the weight is above or below a line running the length of the fuselage.....if the weight is above the line then you'd balance upside down...bottom line is you want the weight down
