ORIGINAL: m82a1pa
Not a problem. Other than the price, is there any advantage of going belt versus shaft? If it's not obvious, I'm pretty left sided on the knowledge bell curve.
If you are learning, you WANT the belt instead of the shaft. It will be more forgiving when you have those other-than-level landings and touch the tail rotor to the ground.
Rafael
