RCU Forums - View Single Post - Checking CG?
Thread: Checking CG?
Old 09-14-2011 | 11:10 AM
Gray Beard
My Feedback: (-1)
Default RE: Checking CG?
ORIGINAL: MinnFlyer
Charlie makes a good point - Remember that the recommended CG is just a ball-park figure. Once you fly it, you should determine if you want to adjust it
Pretty much gets adjusted again every time. I build them so the battery pack can get shifted quite a ways back. I too love the flat spin and stunts that start inverted. Tail heavy I don't do exactly but I do CG at neutral then move the CG as requires a little at a time until I get it where I want it. I always have students start with the CG just a bit on the nose heavy side though then move it as they get used to flying the plane.
