RCU Forums - View Single Post - St g90 gas conversion tuning issues
Old 09-15-2011 | 02:12 AM
mvarzoni
Default RE: St g90 gas conversion tuning issues
Would anybody help me with the post above?
I don“t have any comercial interest on it, it is just for my own pleasure...
I just noticed the piston connection rod is now needding to have a needle bearing...
Does enyone know de needles beearing code to be used there?
I found the HK 0509, but the cranckshaft pin is 6.5mm .
I found the HK 0608, Same issue as above them, I would need to machinery the pin to 6mm and the rod to 10mm wide hole,
Question is, if I do thet will I weak the parts?
Thank you
Mauricio...
