ORIGINAL: grosbeak
ORIGINAL: nefariousrc
I also used a separate control arm along with separate 4-40 control rods on each elevator section. The control rods were then “Y’d “ together inside the fuse using a common servo.
Would you happen to know of instructions on how to do that?
its detailed earlier in this thread. let me see if i can find the post
edit: here's a linkto a couple pics of the modification
http://www.rcuniverse.com/forum/m_89...tm.htm#9892178
Thanks, Isaw those. Ishould have been more specific - how are the rods joined at the elevator servo?
All you needed to do is go to the next page and you would have seen this:
http://www.rcuniverse.com/forum/m_89...tm.htm#9904280
