RCU Forums - View Single Post - What would a gas engine be compared to a glow
Old 09-15-2011 | 11:47 AM
scooterinvegas's Avatar
scooterinvegas
Default RE: What would a gas engine be compared to a glow
ORIGINAL: opjose
ORIGINAL: scooterinvegas
The DLE-20 pulls the same prop at the same RPM as a OS 120AX.
The AX is a two stroker though and it should be pulling a smaller prop at higher RPM's than the DLE.
Out of curiosity, what RPM's did you clock using which props?
I only have DLE-20's and 30's, no 120AX. But in the DLE-20 thread here on RCU, people were comparing the two and they run the same numbers within about 50 RPM's. Favoring the DLE. Im not going to split hairs over a 50 RPM, so I just said they run about the same numbers.
