RE: St g90 gas conversion tuning issues
If the carb throttle "butterfly" is "up side down" or backwards, it will definitely cause problems. High idle, mixture problems, and problems with throttling up. If yours was/is backwards, reverse it and try again.
Your bigger problem is that your connecting rod is now apparently worn out..... Install a new rod if the crank pin is undamaged, and run no less than 16% of good quality oil in your fuel. (160cc of oil per liter of gasoline)
AV8TOR
