ORIGINAL: MetallicaJunkie
ORIGINAL: Gray Beard
My Brison 2.4 is a 40cc and gives about the same performance as the DA 50, also no longer made that I know of. The DLE 55 is a super buy.
are you sure about that, did you mean 3.2?.... my dad used to have a 2.4 and it would swing 18'' props around mid 7s similar to what a DLE 30 can do
Pretty sure it's a 2.4. It pulls a 20X8 Xoar at 7800 RPM. Due to the carb direction I need a tach to tune so it's the only engine I own I remember the RPMs. It still has a bit more lean left in it but I do drop the RPMs a bit.
