RE: Redcat Racing Tornado Thread
Front lower A Arms, glow plugs, Patience. It is a good starter vehicle and should teach you a lot about glow without breaking the bank.
If you keep after the maintenance you should have little trouble but it certainly is a learning curve.
Dont run it lean, use fuel with enough oil (I prefer 20%) .
Adjust the ball joints often, they loosen and the driveshafts fall out.
Tighten the nuts and bolts but not the one on top the servo saver cause it will bind.
