RE: A4 Skyhawk build
I wasn't originally planning on doing the inside of the speed brakes, but after I saw you do yours and then looked at that gaping hole, it was a no brainer. I am going the heavier route with lite ply and G-10 (proskin).
I still need to sand the hole and the slit was to get it on and off while I was fitting it, with out messing with the clevis. The G-10 on top will elimate that, and make a "cleaner" cylinder hole.
I will start the rivets this weekend.
Thanks for leading the way Alex! This is my kind of build thread, keep it up!
