The Ultimate AMA Rant
BPL is a MUCH larger issue to any ham radio operator, and many local radio operators such as ambulance, rescue, fire... BPL would basically close 80 meters through 6 meters, or at least put S 2 interference on everything. RC model use would probably be able to run as normal, as long as you do not fly under/around lines. for 80 meter ham use, the US using this system would ruin that band WORLDWIDE!!
Ryan
KC0LMO
