RCU Forums - View Single Post - Wing mounting options...
Old 09-17-2011 | 09:25 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: Wing mounting options...
ORIGINAL: Fastsky
Hi, I am building a 4o size twin trainer called a Gemini from plans. Its fairly big with a 70'' wing and around 900 sq. inches. The plans call for nylon wing mounting bolts. I am wondering if this would be stronger than a 1/4 ply piece going across the fuselage with the typical blind nuts. It would probably be easier to mount but I am not concerned about that. Any thoughts?? Below is a pic of the plane and the mounting parts that is on the plans.
How far along are you in the kit? Have you heard of "kit bashing"? See attached kit bash concept for your plane.
