RCU Forums - View Single Post - Wing mounting options...
Old 09-18-2011 | 04:35 AM
Fastsky's Avatar
Fastsky
Default RE: Wing mounting options...
Hi Mr67Stang,
Have you heard of "kit bashing"?
As stated in my original post, there is only a set of plans from RCM, there is no kit. I have decided to go with the ply and blind nuts mounting. I have the wing shapes built. That is the ribs were drawn out, cut, and glued to the spars for both wing halves. The fuselage sides and wing doublers have been cut out as well as the 5 formers. I have the vertical stabilizer, horizontal stabilizer, rudder, and elevator cut out. There are 2 marks on the wing doublers for mounting holes. I checked to see what the holes are for. They are for the steel bolts to mount the nylon bits. I haven't seen these before and that's why I was asking about them. I also built a 60 size Cloud Dancer from plans a few years ago so I have some experience.
