RE: Lipo RX battery question
Depending on the current drain, in most cases going with a 5 cell 2000 mah Sanyo Eneloop cells will give you all the advantages you get with LiPo with none of the problems. You can charge them with your old Nixx charger as well and charge them in place. With LiPo's it is advised to always remove them from the model for charging.
