RCU Forums - View Single Post - Lipo RX battery question
Old 09-18-2011 | 06:45 AM
jetmech05
Default RE: Lipo RX battery question
Let me expand on what's been already said......Yes you can run Lipos......but by no means required......a new 700 mAh Nicad will be ok
There are different kinds of Li-XX batteries....Li-ion and Li Fe are a couple....they have the advantage of not needing to charge as often, and hold the voltage better......the down side is with LI-ions you will need a voltage regulator, plus everything for a Li Fe battery such as a good battery charger and longer charge times....a Lipo's max charge current should not exceed 1 amp....
While Li-ions and Li fe batteries seem to be safer during the charge process than Li-pos they still need to be watched
A Lipo if it gets punctured can burn very hot.....they can also burn from over charging.....
In my opinion there is no need to run a lipo get your self a couple of 6V 1100 mAh batteries...that will last you a day of flying plus a tad
Now I do run some Li-Ions in my bigger aircraft...with a voltage regulator....I am getting ready to build a glow trainer I'll run a Nicad 700 mAh in that....
