RE: Flaperons/Spoilerons
Trust me, you really don't want them. Personally I don't like to see flaperons used either as they can create some undesirable situations, but they aren't as bad as spoilerons. If you are landing in a tight area then you need to learn how to properly land the plane. You should learn how to approach so that you can bleed off the speed of the aircraft and make your landing. If you are coming that fast and you hit spoilerons you are going to crash you plane. I'm not trying to sound harsh, but there really isn't any way to cheat on skill. Once you learn how to land properly you should be able to set the plane down where you want it with no problems at all<div>
</div><div>Ken</div>
