RE: How ? Remove old covering from Airframe
when you are using the heat gun don't let the covering get to hot. I normally set my heat on the low setting. Just warm it up in front of where you are pulling the covering off. I then will use acetone to get rid of some the small pieces that wants to stick. Just take your time.
