Originally posted by DMcQuinn
You should be flipping the prop BACKWARDS against compression to start the Moki. Then it generally runs in the proper direction. If it runs backwards, sometimes you can get it to change directions by pulling the throttle trim until it almost quits.
That is exactly right.........
